20 GB data Plan
Alberto_80
Hi,
Currently I have a 20GB / 45$ data plan.
I want my gf to have the same plan, but I can't find it in the web.
Is that plan not  ny longer available ?
BR
Alberto
8 REPLIES 8
Alberto_80
Thanks!
hairbag1
@Alberto_80
still available...
Alberto_80
@softech Thanks for your answer.
Alberto_80
Thank you!
Alberto_80
No, I'm looking at 4G plans, and 20GB isn't visible google chrome/android.
@Alberto_80
To clarify, you were right the Plan page (https://www.publicmobile.ca/en/on/plans#4G)  doesn't show it.
However, as I said, the plan will be available to be selected when you activate or when you change plan
@Alberto_80
You need to click on 4G plan tab first. You are looking at the 3G plans.
@Alberto_80
yes, the plan is still there
if she is new to Public Mobile, when you activate, you will see that plan
If she is existing PM subscriber, just login My Account, click Change my plan button and this plan will be there
