07-17-2017 04:54 PM - edited 01-04-2022 02:22 PM
07-17-2017 08:23 PM
07-17-2017 06:51 PM
Hi also check that it was sucessfully loaded as the add ons are 2 steps.. 1 add enough funds into your account... then 2 add the add on you want...
so if u have funds left - the 2nd part did't work properly
07-17-2017 05:04 PM
try the apn settings
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
If that doesnt work, unfortunately it is time to contact the mods and it`ll take 24-48 hours. Please include sim#, phone#, email used during activation, and detailed description of what happened.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
http://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating/...
07-17-2017 05:03 PM - edited 07-17-2017 05:04 PM
Hi @ksylvest
Check your data setting first. Turn on cellular data.
