Reply
smilingcanuck
phone not taking inbound calls - outbound works fine
anyone dialing my number getting fast busy or no ring.  outbound calling works fine.
Can you please look into this for me ASAP?
Not a new PM account -- been here over 5 yrs.  started sometime in past 24 hours.
Thanks
Dunkman
Re: phone not taking inbound calls - outbound works fine
@smilingcanuck
Does text and data work?
Maybe try rebooting phone
Network reset of phone
z10user4
 @smilingcanuck : Texting in/out? Internet? Which plan?
smilingcanuck
tried, no luck...everything works except inbound calls.
when a person calls me it either doesn't ring on their end or they get fast busy.
I see nothing on my end.
smilingcanuck
old 12 GB over 90 day plan.
Meow
- Do you have another phone handy to try your SIM there?
- I guess you did not change anything regarding call forwarding and similar?
smilingcanuck
not a thing has changed on my end.
Dunkman
@smilingcanuck
As mentioned above, try your PM Sim card in another working phone. This helps determine whether hardware issue vrs PM service problem.
A few other things to try:
Toggle airplane mode on then off
Remove SIM card and put back in
@smilingcanuck  try to reseat your SIM.. happened to me once and I need to reseat my SIM to fix the issue  (power down, remove SIM for a minute and put it back and power up)
Yummy
Maybe cleaning SIM's contact will help a little bit?
