09-01-2020 04:07 PM - edited 01-05-2022 03:44 PM
Hi Guys. Hope someone can help. I have a iphone 5s. I am not able to send or receive pic text to and from non iphone user. I was told it is service provider's issue. I wonder is there any setting I can change to make it happen. Thanks in advance for your help.
09-01-2020 11:39 PM - edited 09-01-2020 11:43 PM
on iphone check if media is enabled in call settings may say wifi or cell data extra charges may incurr enable downloads over data,, ,definatly disable imess and use another msm
09-01-2020 06:08 PM - edited 09-01-2020 06:11 PM
@mimiwong wrote:i do not find the group messaging in iphone 5s. the other are both turned on still does not work
Option 1. Disable iMessage app and just use the SMS/MMS for communication as suggested by @will13am
Option 2. Leave the group messaging off and you cannot participate group messaging. But you still can send and receive SMS/MMS individually.
09-01-2020 05:52 PM
09-01-2020 05:51 PM
i tried that already. It does not work. It stalled
09-01-2020 04:17 PM
@mimiwong , it is likely that you have iMessages turned on. Try turning that off as the default picture messaging service.
09-01-2020 04:15 PM
@mimiwong to send text messages to a non iPhone user enable data, sms and mms. Stay safe.
09-01-2020 04:13 PM - edited 09-01-2020 04:13 PM
@mimiwong wrote:Hi Guys. Hope someone can help. I have a iphone 5s. I am not able to send or receive pic text to and from non iphone user. I was told it is service provider's issue. I wonder is there any setting I can change to make it happen. Thanks in advance for your help.
iMessage uses its own protocol. That is the reason why you cannot communicate with Android user using SMS/MMS. Configure your iMessage as follows:
iPhone Settings for iOS 12.4.5
Under iPhone Messages settings:
iMessage = enabled
SMS/MMS
MMS Messaging = enabled
Group Messaging = enabled
All other Messages settings are disabled
How do you know what message type you are sending or receiving on iPhone?
Messages with green bubbles are normal SMS/MMS text messages.
Message with blue bubbles are sent via the iMessage
