changing the PIN
yvinogradov
can I change the PIN on the account? There must be a way, but I just can't find it...
Thank you!
9 REPLIES 9
@Freakwhensees wrote:
I no longer have the phone
Use the link @RossN provided to send a message.  Good luck!
Freakwhensees
If forgot my pin how do I find mine out
The PIN that you created during activation will have been sent to your phone in a text. See if you still have it.
@RossN  is right moderators are the only ones who can change it for you so just message them.  They did it for me a while back, forgot mine too:)
But you might have a bit of a wait hearing back though.
mimmo
@Freakwhensees expect about 3-4 days reply time
@Freakwhensees hi with respect to obtaining your account PIN, you will need to get in touch with the moderator team.  The moderator team can be reached via private message using this link.
Freakwhensees
hycm53
Thank you!
You can only pick your own PIN when you activate Sim card and set up self service account. After set up I'm not sure you can.
hairbag1
Thank you!
You'll need to contact a moderator to change the pin.
Click this to message them.
