05-13-2021 11:40 AM - edited 01-06-2022 02:42 AM
05-13-2021 10:57 PM
I hope after some time you are now able to send/receive texts.
If not, try resetting your device's Network Settings.
If you put your SIM into another compatible Public Mobile phone, does texting work then?
05-13-2021 04:19 PM - edited 05-13-2021 09:31 PM
05-13-2021 01:16 PM
Is it possible your iMessage or Chat settings are not allowing SMS?
If Android, try adjusting Chat messages options.
For Apple, adjust the iMessage settings:
05-13-2021 01:02 PM - edited 05-13-2021 01:03 PM
You tagged your post as porting. As @Anonymous mentioned if you did not leave your old sim card in your phone to recieve the porting authorization text and respond YES to it within 90 minutes you will have to reintiate your port request. You can do this by contacting the moderators or by calling the telus porting department.
If you cannot make calls or send texts on your pm sim card then your activation did not set up correctly. Then you must contact the moderators first. I suggest sending a private message.
Contact the moderators by sending a private message and leave a detailed message explaining your issue and the info to verify your account by including the following information:
If you cannot remember your pin # include at least three of the following:
The average wait time is 2 to 4 hours but be prepared to wait up to 48 hours for non urgent requests. Current wait times are about one hour and are probably even less if there are new trainees. Keep an eye on your private message box the envelope icon next to your avatar for a little number to pop indicating a message from the moderators. Responding promptly will speed up service times.
Do not post any of this info in the community only in your private messages when communicating or contacting the Moderator_Team.
To send a private message to the moderators click below:
05-13-2021 12:00 PM - edited 05-13-2021 12:20 PM
do one thing take your SIM card out and waiting for a minute and put it back and do rebooting your phone - This one is quick and simple. Make sure your phone is off before removing and reinserting its SIM card.
Remove your phone’s battery - Some phones have removable batteries. Sometimes removing and reinserting the battery can fix certain issues. Just make sure your phone is off before you do this.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and make sure APN Settings On device
Changing APN Settings On An IPhone
click HERE
Changing APN Settings On Android Phones
click HERE
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is go through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
Good Luck
05-13-2021 11:51 AM
Regulars: view the tags box.
@Maggie05 : Are you sure you can't send texts? It's normal during porting to not receive calls and texts until the port is complete. Did you leave your old SIM in to confirm the port?
05-13-2021 11:47 AM - edited 05-13-2021 11:48 AM
@Maggie05 Was it just text you have issue with ? Incoming calls and outgoing calls?
What kind of phone is that?
Also, just to confirm, you have been an user for some time or just joined PM? If you have been with PM for sometime, did you just change your phone?
05-13-2021 11:46 AM - edited 05-13-2021 11:51 AM
Have you ever been able to send or receive texts ? You need to enable data even though it does not use your data.
Make sure you have the correct APN settings.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these setting.
