06-14-2021 09:26 PM - edited 01-06-2022 02:52 AM
Hello I’ve been with public mobile for about 3 months and suddenly the SIM card says invalid, turn the phone off then back on works for a while then does it again, I just guessing the sim are is messed up so I order some new ones but I’m curious about this fraud thing could that have anything to do with it? Seems strange it works then doesn’t any info would be great
06-14-2021 09:39 PM
@BCote wrote:Hello I’ve been with public mobile for about 3 months and suddenly the SIM card says invalid, turn the phone off then back on works for a while then does it again, I just guessing the sim are is messed up so I order some new ones but I’m curious about this fraud thing could that have anything to do with it? Seems strange it works then doesn’t any info would be great
Try a RESET of your Network Settings with the device you are using now.
Do you have the ability to try your SIM into another phone and use it for a bit to test?
If issue still persists, than one could say this is not a device issue, but a Network, Account, or SIM issue.
06-14-2021 09:37 PM
Your welcome. Report back your results. We will continue to troubleshoot it if it continues to occur.
06-14-2021 09:34 PM
Ok Thankyou everyone I’ll try these suggestions
06-14-2021 09:32 PM
Remove your sim card and carefully clean it. Check the sim slot for any dirt or debris. Does the sim card sit snugly in the slot? If not secure it with a paper shim or a carefully placed piece of tape. See if that prevents the error message from occuring.
06-14-2021 09:31 PM
I do not believe that this is an issue of fraud, as if it were, your service would not start working again after restarting your phone.This could be a sign up a localized network issue. I've had my phone say "Unregistered SIM " during a time of a network outage.
