Re: calls going to voicemail instead of ring
dkai12
now when I switch to 3G I'm not able to text message Pictures .
new issue.
23 REPLIES 23
@gpixel wrote:
we're getting volte!
 @gpixel LOL but admittedly these could be some transitional growing pains. They have to move out of 3G eventually.
@dkai12
That all depends on the nature of the problem and how to fix it but given that its affecting several customers that we know about and telus is involved that you can be assured its being given a high priority. I imagine that this an technology/infastructure problem vs a system/account issue but either way I am sure they are scrambling to find its source and/or rectify it as quickly as possible.
dkai12
OK
How long will it take with TECH team
@dkai12
Ask for the tech team ticket reference # so when you ask for an update you won't have to explain the whole issue to a new moderator. They will be able to easily just check the ticket # for progress.
@dkai12  you can reply the message and ask Mod to provide you an update.
Yes, Wed is around the day we saw people posting about the issue.
dkai12
escalated to TECH team,
dkai12
they are escalating it to TECH team.
but issue been on going since WED
dkai12
says I'm on KOODO network
dkai12
I tried all.
3G should be able to send MMS as well.
Have you open a ticket with Mod yet?  I think you should , tell them your situation, only 3G works for voice and LTE for text/MMS and see what they say.
@dkai12 , can you confirm your data is set to on?  Although it doesn't consume your data, it needs to be on for MMS.
Also, just for a test, you can try to change it back to LTE and see if the MMS goes through
dkai12
Yes turn to LTE I can send text messages pics but NO incoming call again!
@dkai12
MMS should still work on the 3G network.
@dkai12  SMS and MMS would work on 3G too.    Can you confirm if your Data in turned on?
also, just a test, did you try to change it back to LTE and see if you are able to send and receive SMS and MMS?
dkai12
Yes
But can't sent Text Messages with Pictures now.
@dkai12  you have changed to 3G Only?  but are you going incoming calls?
dkai12
Still not connected to LTE
network
also my text pics are not working on 3 G
unacceptable
don't know what happening, but it has been couple days for sure.. i have a feeling it's not just Ottawa.
@Anonymous
I have no issues with calling in Vancouver. Both my phones rang when I called them.
dkai12
Yes out calls work
thanks
