Re: Iphone SE 2020 (2nd generation)
Mike52
Hello I have iphone 2020se   >  Where /how do I enter MMSC into my iphone?  I can not find how to do this on settings menu
Thanks in advance
Mike
TheGx
Remember to let us know and post if these suggestions worked for you too.
Mike52
Hi thanks for those suggestions on solutions to my question.  I will try them.  Good to know that the phone automatically sets MMSC settings, this explains why there is no input ability to do that. Makes sense
@Mike52
@Mike52 wrote:
I have iphone se 2020 and am having same problem as you. Can not find how/where to enter MMSC information
I can make voice calls but sms not working
Did you find a solution??
You should not need to enter MMSC information of iPhones.  It should be automatic.  Does your data work?
Maybe try rebooting your phone.
Network reset of phone
Toggle iMessage off/then on.
Make sure SMS texts turned on, as well as MMS
Aside: I will be splitting your question to its own thread.  Better visibility.
Mike52
