Re: I couldn't get incoming calls. it goes to voicemail right away. Help please!
dkai12
Please help
my calls going into voice mail directly
46 REPLIES 46
dkai12
still not working
how long do moderators take
@redditpirate
Try disabling LTE as mentioned earlier in this thread. Maybe Telus has broken LTE➡️3G handoff in some areas. If so, hopefully only temporarily.
Interesting if it may be geography specific - wonder where the others are that are reporting this. Incoming is working here in Regina SK
can you do try reseat the SIM
1.power down,
2.take out the SIM,
3.wipe it clean,
4.put it back and power it up,
it happened sometime you know, A normal reboot without reset didn't work.  At least try it,
only work after reseating the SIM.
redditpirate
I am having the same issue in Ottawa. Not receiving incoming calls anymore, straight to voicemail. Can still call out.
dkai12
ill try that
is your phone SIM card before working fine with that device if so,
maybe the issue with your device you know
do you can try your SIM card with another device,
can you do factory reset. if you like it
Good Luck
@dkai12
You can also try moving your SIM into another phone to see if the issue is with your device, or the service/coverage.
dkai12
I'm trying no luck
@dkai12
Yes we all know your phone is not ringing. But you are still not answering my question:
Did you try my previous suggestions to disable LTE and dial the call forward reset codes?
dkai12
phone not ringing
@dkai12
Did you try my suggestions?
dkai12
I need help
Nezgar
@dkai12
  • Try forcing your phone to 3G mode (aka HSPA or WCDMA) - disabling LTE.
  • Try undoing any call forwarding that might have been inadvertently set by dialing ##21# and ##004#
Lastly, ensure any features that could block calls are disabled - block anonymous callers, DND.
1.power down,
2.take out the SIM,
3.wipe it clean,
if is still have same issue you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • or you can send a private message to Moderator_Team by Click here
  • You’ll need to be logged in to your Community account for the link to work.
  • In your message put it, please include.
  • your account number,
  • your phone number,
  • your account PIN,
  • explanation to them nice Team and nice service
      Good Luck
dkai12
ill try that
please help
dkai12
same here
please help
