11-13-2020 03:18 PM - edited 01-05-2022 05:26 PM
I was wondering if its possible to check PM Voicemails on another device? Thanks
11-14-2020 02:21 AM
You can even check your voicemail from another phone, without ringing your own phone. Just dial any of the access numbers across Canada listed here:
Press 1 for English, enter your phone number then #, then * during the greeting, then your PIN and #
11-13-2020 03:21 PM
@Anonymous Yes call your cell number. When voicemail starts to play press star * then enter your password.
11-13-2020 03:19 PM
@trgtrg2020- absolutely, you can check from anywhere. If you are on a limited minutes plan (like the 15$ plan), you are better off checking from a land line or voip line, in order to save your minutes.
