11-30-2016 03:15 PM - edited 01-05-2022 01:05 AM
Hi,
I'm trying to port over a Rogers # but already have an active PM phone #. I went through the self-serve porting process but was shown an error msg & advised that PM is having difficulties and to contacPM for assistance (this is what I was hoping to avoid given how painful of a process it has been for many new custormers). Question is: Am I not able to use the self-serve porting form to port over a Rogers # if I already have a PM #? Do I necessarily need to contact one of the Mods for assistance to complete the port?
Thanks.
12-08-2016 02:47 PM
11-30-2016 04:14 PM
@In4Lb Ah, shoot. I had the same problem when I first started and that was the fix for me and a lot of people; sucks that it's not the case for you. And don't worry, my port went by quick and easy. I can't imagine how it is for people like you waiting for a while, so I understand your frustarated. Hopefully a mod can pick up on this soon.
11-30-2016 03:52 PM - edited 11-30-2016 03:56 PM
@d_mcbay Yes, of course, that's pretty obvious and I have already tried it to no avail. Edit: thought you meant just to check the box, which I did, but I see you meant same as @UDP7. Don't mean to be rude just frustrated.
@UDP7 Thanks, but no luck either.
Stubbled upon a mod name here, maybe I'll try to tag him: @Jeremy_M
11-30-2016 03:39 PM
@In4Lb If you refresh the page, tick the I am autorized to transfer this phone number box first before filling anything out. For some reason this has fixed that problem.
11-30-2016 03:35 PM
Try ticking the box that says "I am authorized to transfer this phone number" before you do anything on the page. That should make it work!
11-30-2016 03:28 PM
Yes, affirmative to your 3 conditions. But apparently PM won't allow me to port in. At times it also gives the following error message: "You must be authorized to transfer this phone number" - And yes, of course I am authorized to transfer it; in good standing, and still active #. Frustrating!!!
11-30-2016 03:19 PM - edited 11-30-2016 03:22 PM
Yes, you will be able to port in your Rogers #. Provided:
Since you got tripped up on some kind of error, you definitely should contact the moderators via private message.
You should follow the suggestions here when you send a private message to the moderators.
Hope this helps,
Neil
