Reply
TheoE
Re: Picture Messaging Stopped Working on P20 Pro
Hi All,
I was wondering if @fch you found the solution to this thread?
I purchased a second hand Huawei p20 pro a month ago, I've been able to call, text, use data on various apps. The one thing that keeps resisting me is MMS. Specifically, receiving/sending picture messages, receiving/sending group text messages.
I previously owned a Sony Xperia XZs, MMS worked no problem.
My plan details:
  • 100 Minutes Canada-Wide Talk + Unlimited Incoming Minutes
  • 250 MB at 3G speed
  • Unlimited International Text
Besides this thread, I've tried troubleshooting with the following without success.
https://www.publicmobile.ca/en/ab/get-help/articles/set-up-data-on-an-android-phone
https://apn-canada.gishan.net/en/apn/public-mobile/huawei-p20-pro
https://consumer.huawei.com/en/support/content/en-us00407026/#:~:text=Verify%20that%20the%20APN%20se....
My APN settings:
Couple things I haven't tried: 1) different messaging app 2) factory reset. I'd rather avoid those if possible.
Dunkman
@TheoE
Is your data turned on?  Does data work?
MMS texts won't use up data allotment but it needs to be turned on.
Might want to change a couple lines of APN
MVNO type: GID
MVNO value: 4D4F
z10user4
 @TheoE : Try
APN Type = default,mms,supl
MVNO Type = GID
MVNO Value = 4D
Also could try the last one = 4D4F
TheoE
Thanks for the quick response @Dunkman & @z10user4 .
I confirm my data is turned on, I can do a google search. I haven't reached my total allotment either.
I tried both of your solutions but it does not seem to do the trick.
In doing so however, I rebooted the phone after each change and noticed that maybe 70% of the time, when I come back in the APN settings after reboot, it had reverted to the default APN i.e. it didn't have the "Public Mobile 2" APN selected but the default "Mobile Internet".
I wonder if that's the problem. Found this thread online, I'll give it a try tomorrow.
https://forum.xda-developers.com/t/apn-settings-revert-after-every-reboot.3505041/
z10user4
 @TheoE : Of course you need to save your work and select the APN.
Are you able to delete that other one? Or edit it instead of making a new one?
I tried that code on my Samsung and it didn't work. It might only be for LG but I don't know.
Another edit you could try:
MMS Proxy = mmscproxy.mobility.ca
MMS Port = 8799
