Phone Compatibility
Ron22
Does anyone know if Honor 8x JSN L23 will work with this network?
Ron22
I guess I was reading spec wrong,
I though it covered all 3G bands and only 1 LTE band.
Thanks for help.
bridonca
If already have this phone, it should work, but only if the very few frequencies this phone supports is available.  I would not buy this phone if I planned to use it in North America.
will13am
@Ron22, unfortunately this model of phone is not sufficiently compatible with Canadian networks that I would recommend using it.  Public Mobile runs in 850/1900 Mhz for 3G service which is essential for phone calls.  This phone only has 850 Mhz.  Connectivity is going to suffer as a result.  For data on LTE, the compatible bands are B2, B4, B5, B7, B12, B13, B17, B29.  This phone has just one of the LTE bands.
Here is the specs for the phone.
https://www.gsmarena.com/honor_8x-9313.php
Here's the specs for the network.
https://en.wikipedia.org/wiki/Telus_Mobility
hycm53
Or try PM checking:
https://www.publicmobile.ca/en/bc/get-started
hycm53
Check your phone using this two links:
https://willmyphonework.net/
https://www.kimovil.com/en/frequency-checker/CA
duffer900
Good place to check
http://willmyphonework.net/
