One contact does not receive my texts
Naturediver
An interesting problem.
A friend of mine that I referred created a public mobile account about 10 days ago and installed his new sim and used my referral code.
Next day, his old provider gave him a deal and new phone that he could not refuse.
He cancelled his public mobile account.
Now he does not receive my texts.
I can phone him and receive his texts.
Other public mobile users can text him. But not me.
I have deleted/added him to my contacts, cleared text log, rebooted phone, removed sim and rebooted.  But, he does not receive my texts.
On his end, he has a new Apple phone (Verizon sim), has removed me, added me, checked that I am not blocked, and he receives texts from everyone else.
Almost looks like I am the only one blocked by the public mobile network?
This should probably go to tech support.
Cheers
Derek
18 REPLIES 18
Naturediver
I receive green bubbles. So his sms is on.
Thanks.
I have now sent my problem to a moderator.
Appreciate your ideas.
Naturediver
Thanks.
I have cleared message cache, and stop/started app.
Have not reset apn settings.
Cheers
Derek
@Naturediver have you tried resetting your network settings? clear your messaging app cache
Naturediver
Thank you yes, that is it.
A bit of a brain fart on my end.
cheers
Derek
Naturediver
Thanks I have tried that, and also tried removing sim card.
But I think you are on the right track, and I think PM may have to do something on their server end.
Cheers
Derek
popping
@Naturediver
Your phone may still remembered that your friend's number is still located at PM network.  But it does not make any sense.
Restart your phone just for fun.
BeachNBeer
@Naturediver  Maybe you meant to say Virgin mobile?
Naturediver
I think I better check the carrier.  He is here in Canada in my town.  I think I put in the incorrect carrier.  Have emailed him for the correct one.  Sorry about that.
It is not a US carrier issue, as he has a Canadian carrier.
thanks for your response
BeachNBeer
I am curious though. Public mobile is Canada and Verizon is USA. So where does your friend reside? You can't port a USA number to public mobile so....I'm confused now
BeachNBeer
So if the issue existed on two of their phones. Maybe he should contact Verizon and ask?
Naturediver
Thank you, this has been tried.
Also the problem also existed with his previous phone.
Cheers
Derek
popping
@Naturediver wrote:
Thanks for your reply.
I am using an Android and I receive his messages just fine. I have not problems will all my other contacts.
Before he had the Public Mobile account, he received my messages as well.
It was after he created and subsequently cancelled his public mobile account, he would no longer receive my texts, and I would still receive his.
He is able to send/receive to all his other contacts who have both Iphones and Android phones.
I know, interesting problem.
Cheers
Derek
Ask him to restart his iPhone since he switched provider from PM to his previous provider.
BeachNBeer
Well it's not Public Mobile blocking it because he cancelled considering you receive his texts and you're on Public Mobile.
darlicious
@Naturediver
It sounds like there is something in his settings blocking your number like do not disturb. Do you have a number with a new exchange or perhaps Verizon doesn't recognize your number for some reason.
Naturediver
Cheers
Derek
popping
@Naturediver
Are you using Android phone?
If yes, your friend need to configure his iMessage to send SMS/MMS to you instead of using iMessage protocol.
Under iPhone Messages settings:
iMessage = enabled
SMS/MMS
MMS Messaging = enabled
Group Messaging = enabled
All other Messages settings are disabled
How do you know what message type you are sending or receiving on iPhone?
Messages with green bubbles are normal SMS/MMS text messages.
Message with blue bubbles are sent via the iMessage
Naturediver
Yes, his settings are correct as he is receiving texts from other Public Mobile accounts and everyone else in his contacts.
Thanks for responding.
Cheers
Derek
BeachNBeer
Your friend got a new iPhone. Are you sure his settings are correct? Maybe he has it setup simply for iMessage. He would have to go into his settings and turn on sms.
On that note has he contacted his USA carrier about this or only you in here?
