Not registered on nerwork error
Leslie13
13 REPLIES 13
Daps
@Leslie13  It does sound as if your phone may be blacklisted.
You can verify here: https://www.devicecheck.ca/check-status-device-canada/
@Leslie13 @brettster99
APN settings are unrelated to network registration. Those settings could be blank and network registration would still work to compatible networks with an active service. APN settings only enable the use of cellular data.
@Leslie13  Where did you purchase that phone? Was it a retail location or a person? Is your phone blacklisted?
@Leslie13 to reset your network settings
Procedure
  1. Open the Settings app
  2. Tap General Management
  3. Tap Reset
  4. Tap Reset Network Settings
  5. Tap Reset Settings
    • Note: If prompted, enter your PIN, password or pattern
  6. Tap Reset Settings one more time to confirm
Restart your phone if it doesn't automatically do so. Stay safe
Leslie13
Phone is samsung A series
Leslie13
I did not make any reset nor changed APN
@Leslie13 Try a network reset and restart your phone if it doesn't automatically do so.  Stay safe.
Leslie13
Samsung A
brettster99
Have you tried resetting the phone? Have you changed APN settings?
We kinda need a little more information to help you out
Leslie13
Sim card work on other phone
gblackma
@Leslie13 what's the make and model of your phone?  Thanks.  Stay safe.
Leslie13
kb_mv
@Leslie13 Are you new? Is your phone unlocked? Can you try the Sim in another phone? Are you porting a number in?
