No incoming call
mdasif
Help from moderator please.
iam able to make calls but no incoming calls are coming in. please help
8 REPLIES 8
@mdasif Are outgoing calls work. If both aren't working, are you on an old $10 or $15 plan without unlimited incoming?
geopublic
@mdasif  Do your calls go into voicemail? If yes, check the privacy settings on your phone. Maybe you have do not disturb on. Also check your usage logs to see if the calls are coming in by accessing your selfserve account.
@mdasif
@mdasif wrote:
iam a existing customer. have  had this line for 2 years. my phone number is
@mdasif what is the make and model of your phone? try airplane mode for 5 minutes then restart your phone
JoyLuck
Contact the Moderator Team (Public Mobile representative) for assistance:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work
@mdasif hi try restarting your device.
1. Open Settings>General Management>Reset
2. Tap Reset Network Settings>Tap Reset Settings
If prompted enter your pin, passcode
3. Tap Reset Settings 1 more time to confirm
4. Restart
@mdasif plese edit your post you are on a public forum click the 3 dots top right corner to delete your info
mdasif
iam a existing customer. have  had this line for 2 years. my phone number is xxxxxxxxxxxxxxxxxxxxxx
edited by computergeek541: removed phone number
iliketotalk
@mdasif hi if you just ported a number it may take a few hours give it a little time
