No Data on Iphones!!!
ChrisM7
HI, so yesterday i ported over two numbers which both got sms confirmation that the port went through.
Though when trying to access the internet/data, both iphones were not able to connect to data
I have an iphone 4s and iphone 5 both which i inputted to pm imei tested to see if they were capable with pm. Both were able to work with pm
I tried putting the sims into an iphone 6 plus and both of the sims work on data
I need help with my iphone 4s and 5, I also see that the only apn setting on the cellular data was for hot spot
I also found out that both phones on the setting->general->about showed that for the carrier it was not public mobile but either rogers or telus.
Anyone know how to fix this problem as it seems i have no data for either phones.
See how carrier says rogers instead of public mobile 24.0 my other iphone 5 says telus
ChrisM7
Thanks man, i went through the other discussions and finally found out how to change the apn setting by using a site
mimmo
Do they have most recent software?
Also I vaguely recall reading somewhere iPhone 4 might not be supported or something because of lack of software updates.
mimmo
ChrisM7
Yes i rebooted, reset network, restore my iphones still nothing
for some reason only works on my iphone 6 plus
jeremyclee
At the risk of asking the obvious, did you reboot both phones?
I'm surprised your data worked on the iphone. on my iphone 6, i had to change the apn to sp.mb.com
