My Data is not working
rockinbruce
I have an IPhone 7 and my data stopped working….
13 REPLIES 13
@rockinbruce wrote:
Yes I have plenty of data left.... I think I have the problem solved but I'm not sure as I'm home now and I'm using wifi...... Thanks for your response....
@rockinbruce  you can test by turning off the wifi and see if data is working
If you need more help.. let us know.
rockinbruce
rockinbruce
Thanks for your help....!!
@rockinbruce
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
How to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  HERE
click HERE
Ensure you have the correct APN settings by visiting HERE.
and check it out at self-serve  account. Review the rest of the data left !
@rockinbruce
or visit  HERE
click HERE
rockinbruce
How do I confirm that my settings are correct?????
... also, did you reboot?  you tried to use data with different apps?  or all failed?
What plan do you have ?  Any chance you are out of data?
Logon to My Account and confirm.  On the Overview Tab, if you see a line about Mobile data, it will show you how much you are have for the month and how much you used.
If you don't see such a line, all your data are used up.
@rockinbruce
Look at the postings in your first thread.
rockinbruce
I have an IPhone 7 and my data suddenly won’t work…. Please help !!
Staliger
@rockinbruce Check your Self-Service account. How much data does it show there, if any?
JK8
Confirm your cellular data is on and your apn settings are correct. Also log into self service and look under My Data & Add-Ons to confirm you have data left.
