Moto G X1032 and 3G
Heavyrocker
Hi all,is 3G still ok for this older phone or should i go with 4gG and will i need a new simm card as well?
PBForMe
There's no 4g specific SIM if that's what you're asking, yours is LTE capable. Whether it will fit depends on what size you have now and what size your new phone has as @Jak mentioned.
You'll probably go from micro to nano sim, and assuming you have the punchout type sim, you could just pop out the nano from your current mirco sim.
Heavyrocker
Its unlocked ,Thanks for the help,reason why im asking is because the phone i have,the older Moto G XT1032 and the plan i have is only 25/mo.Im in Toronto and i just use it as a replacement for a landline,i do all my stuff on my desk top.I am planning on trading stocks with phone so looks like i may as well go for a new phone and faster speed,i will need it..LOL.How bout i upgrade to a ''4G simm card',will this fly?
PBForMe
I wouldn't bother, 3G HSPA should give you around 15mb down/8mb up more or less, depending on area which is plenty fast.
JaK
Hi @Heavyrocker
Assuming this phone is unlocked, it should work fine for you on 3g. In general. there are very few (if any) areas that you will have 4g coverage without 3g. The only difference you should see is a little slower data.
As to the need for a new sim, depends on what you have now. If you have a recent tri-sim, you just need to punch it out to the right form factor (micro sim for that phone).
Good luck, let us know how it goes.
