03-09-2019 03:10 AM - edited 01-05-2022 06:49 AM
Hi
Has anyone else encontered problems not having data with the LG G Flex Phone?
Cause I switched the Sim card to my LG X Power and had data right away.
I guess with some models you need to put in Public Mobile Data codes.
Seems odd some phones require a big set up and others just put in Sim card and go
03-09-2019 06:42 PM
@Patrick_R many LG models require a network reset--and if that doesn't work, a factory reset--to get data flowing after changing carrier. If you need to do a factory reset, make sure you back up anything you want to keep first.
03-09-2019 08:54 AM
@Patrick_R , regardless of the model of phone, I always check that the APN settings are correct as part of the steps to setting up the phone for use with a particular service provider. It is an essential step if the plan includes MMS and data.
