Reply
Dianeena
International Calls - 400 min add on
I buy the 400min add on to call to France but I can't make any call. Does someone can help me please 😕
hairbag1
Re: International Calls - 400 min add on
How to call France from Canada
  1. Step 1: Exit code – 011.
  2. Step 2: Country code – 33.
  3. EXAMPLE: 011 33 1 44 xx xx xx. A correctly dialed France city phone number will ensure your call will end up to the correct destination.
kselmak
Did you purchase the add-on
Does it show in your list of add-ons?
It's a 2 step process, it will take you to payment but that is not complete you must go back to ad it after you have enough funds
International dialing starts with 011 then country code
geopublic
@Dianeena  Purchasing the addon is a two step process. First you add the $15 to your account and then you purchase the add-on.
To verify that the addon is added to your account dial 611 from your phone or access selfserve and check the first page to see if the addon is listed.
If yes, then you should be able to make the call.
cellphoneuser1
@Dianeena
Try +33 before the number.
Dianeena
I have tried that but I kept having this answer " 8UM1, L'appel ne peut être acheminé au numéro composé."
Triguy
Check your self serve account under data and add-ons to make international calling has been added.
Purchasing add-ons is a two step process.
https://www.publicmobile.ca/en/on/get-help/articles/purchase-add-ons-through-self-serve
Dianeena
I have checked on 611 I have the 400 min add on.
hairbag1
Log into your account / My Data and Add-ons to confirm that you actually have the 400 minutes of International Calling add-on applied to your account properly.
Triguy
