08-13-2020 04:01 PM - edited 01-05-2022 12:47 PM
08-13-2020 05:00 PM
Hi,
Check at overview page of using self serve tool, and verify if your add-on has been included in your available services.
Second, verify that the rates of the destination are within this limit that you have purchased.
08-13-2020 04:13 PM
Have a look at your overview page and see if you can see the add on you purchased? Which one appears there?
08-13-2020 04:11 PM
08-13-2020 04:08 PM
If your contacts are Canada or US then try adding a 1 in front of the number.
If you got a roaming add-on then you need to be in the states.
If you still see the $8 in your account then you've done step 1. Now you need to finish the purchase by doing it again.
08-13-2020 04:07 PM
@07allanj which plan are you on? And which country are you trying to call? Thanks. Stay safe.
