Data not working
jasminel
Hi, my current plan ends December 18. I saw the Fall 2016 promo last night and added it to my account making it 'renew on the next cycle" so it starts on December 19 with the 90 day /4gb/$40 Fall2016 promo. However, my data has stopped working since then. Did i miss a step to changing my plan?
10 REPLIES 10
srlawren
@jasminel wonderful--I'm happy to hear that!
jasminel
thanks! i found my solution!
jasminel
thanks! i found my solution by removing and putting the sim card back in!
jasminel
srlawren
@jasminel have you tried the things @neilselden suggested?  Are you still having an issue or has this been resolved?
neilselden
Hi,
Odd issue.  if you don't mind, try these basic troubleshooting steps:
1) Check to make sure that you have cellular data enabled on your phone
2) Log into your account on the web and verify that you have data left.  If you do have data left, proceed...
3) Power off phone, remove SIM card, replace after 1 minute, power on phone.
4) Check data connection, if still no data, proceed...
5) Under Settings -> Cellular Networks --> Access Point Names; make sure 'Mobile Internet' is set
    to 'sp.mb.com' (omit quotes)
6) Check data connection... If still no data, contact a moderator.
Hope this helps,
Neil
Saray_O
Hi @jasminel
I'm sorry to hear that. I have checked your account and everything seems to be active and there doesn't seem to be any system errors on our end. I also see that you scheduled the plan change correctly.
I have refreshed your connection to your network to see if that helps. Could you reboot your phone and see if you can use data now?
Thank you!
*Please do not post private info such as: phone number, account number, pin etc.. This is a public forum.
JaK
PM sends out warning texts as you approach your data cap (at 75% and 95% I think), so should have those if it is a cap issue.
WearySky
I assume you've checked your data usage, and it's not just a coincidence of you hitting your data cap at the same time? 🙂
JaK
Hi @jasminel;
Setting you plan to change on renewal should in no way effect your current plan, so no I don't think you missed a step and it is likely not related at all. Did you do all the normal things to get data working again, like check your phone settings, reboot your phone, etc. Also, have you logged into self serve to see how much data you have left?
