Hi there ,
I registered for an account 2 days ago, my calling and text are working but my 500mb+500mb for data is not working. What can I do to solve this?
@junlu wrote:Hi there ,
Make sure your APN is setup as follow:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
@junlu what is your phone's brand and model? Some have special steps you need to take.
My phone is XiaoMi Mi A2
Yes, it's.
Ues my XiaiMi A2 default APN has the same details as you said, but still doesn't work.
BTW, my XiaoMi A2 couldn't create an new APN
The problem is partly solved! I get the other SIM card out left the public mobile stay, than, I can use data. But still couldn't use data while I am putting 2 SIM cards in.
@junlu wrote:The problem is partly solved! I get the other SIM card out left the public mobile stay, than, I can use data. But still couldn't use data while I am putting 2 SIM cards in.
@junlu if you're using two cards at once, you need to set which one is active for data. (Unless your phone happens to be dual-active dual-sim--almost all dual SIM phones these days are dual-stanbdy dual-sim, meaning only one can be your active data connection at a time. You probably have it set to the other card.
