Data not working,after payment
kaurjasmine1247
I have reactivated my plan ... But my data isn't working ..!!!.
8 REPLIES 8
@kaurjasmine1247 wrote:
Yeah ..my plan was suspended ...it was of $40 ..I have made the payment ..it's been time....I need my data urgent...please help
@kaurjasmine1247    Did you click the Reactivate button after making payment as suggested earlier?
@kaurjasmine1247   Did you login to My Account and confirm if the account status showing Active?  If so, reboot your phone.  Test if you can make  calls and then data
If it is still showing Suspended, check if you see the full $40 showing as Available Fund on My Account.  If so, manually load $1 more.  If it goes through, click Reactivate current plan.  Logoff My Account and reboot the phone.
@kaurjasmine1247, have you verified that your account status is Active now?  If it is I would try re-booting your phone.  You could also remove your SIM and re-insert it.  If none of that works you will need to contact the CSA through the chatbot by the bubble in the bottom right hand corner.
kaurjasmine1247
ShawnC13
So was your plan suspended then you paid and re-activated?  Have you re-booted your phone?  What plan are you on, if you are on a small data plan once you re-activated maybe somethings in the background may have updated or using data in the background and used it.
@kaurjasmine1247
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and you can try to reset network settings and Changing APN Settings,
Spoiler
for IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do again Rebooting your phone,
or you can try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
This is quick and simple,
Meow
What about SMS/calls? Do they work?
Do you have enough data on your account? Check account status for GB/minutes left.
Triguy
Make sure you have the correct APN settings.
Try rebooting your phone.
