Data Usage History
sgbrittain
Obviously during the course of a billing period I can log on here, check my account and see my data usage so far during that billing period.  But how do I see my data usage for last month or last October?
2 REPLIES 2
Tav
@ooakosiryan wrote:
Try going to Plan and Add-Ons, then Usage History (all the way on the right of the top menu). There should be approx. 3 months worth of usage, and you can select the date range you're interested in. Hope this helps!
This doesn't add them up for you. Technically you could figure it out this way but it would be very annoying. Depending on your phone you may have a usage history. For example: On Android 7.1.2 you go to settings>data usage>mobile data usage and on here a drop down to select previous months.
ooakosiryan
