Can't send or receive MMS
chung01
I can't seem to receive or send any MMS. Using Samsung S6 and google messenger app. Attached are my APN settings. Screenshot_20170305-115543.jpgScreenshot_20170305-115618.jpg
11 REPLIES 11
I don't see anything obvious. Are you able to try your SIM in another phone?
chung01
oops. picture didn't load for some reason
chung01
@sheytoon
IPv4 is correct. Your settings appear to be correct. Can you delete your secondary APN and share the lower part of the first APN's settings?
A rediscovery that may not help from @s2scotty
If you have multiple APNs listed, ONLY one, the PM one, should have the APN type "default".
Including "mms", as in, "default,mms" makes it clear TO THE PHONE to route MMS via this APN/carrier.  IT APPEARS CRITICAL THAT there are NO SPACES between the words and the commas (e.g. "default,<space>mms" = wrong and "default,mms" = correct). A trailing space proved an issue on a phone (e.g. "default, mms<space>" = wrong and "default,mms" = correct). Like "default", only the correct and active APN should include the "mms" tag.
*  Name: Mobile Internet
   APN: sp.mb.com
   Proxy: Unspecified
   Port: Unspecified
   Username: Unspecified
   Password: Unspecified
   Server: Unspecified
   MMSC proxy: 74.49.0.18
   MMS port: 80
   MCC: 302
   MNC: 220
   Authentication type: Unspecified
*  APN type: default,mms
*  APN roaming Protocol: IPv4
   Bearer: Unspecified
   MVNO type: GID
   MVNO value: 4D4F
chung01
can anyone comment if APN protocol should be solely IPv4?
imm1304
Hi @chung01!
Try this:  1.  Delete the second APN for MMS
2.  Edit the 1st APN to include the following under APN Type: default,mms,supl
note there are no spaces after commas.
Save changes and reboot the phone.  Test MMS.
chung01
@will13am i had the first apn and saw on another thread someone added a second one that's specifically for MMS. That didn't work for me. Already enabled it as the default app
will13am
@chung01, why do you have two APNs?  The first APN combines data and MMS as noted in APN type. That may have an effect.  I have not used the google MMS app before.  Is there settings to enable it as the default app?
chung01
a) data is turned on
b) all other data connections work
c) pictures don't go through at all. MMS doesn't utilize wifi... regardless it doesn't work with or without wifi.
Luddite
a) be sure cellular data is turned on.
b) do all other data connections work?
c) do pictures go through on wifi only?
