Can't make calls
Sheri1
Bill is paid but states mobile network not available to make calls
10 REPLIES 10
BabakR
Thanks everyone, I googled how to restart it (duh! hold power button and then three options appear, one of which is restart!)
It worked, I am now connected once again to the network.
Thank you!
Hope everyone is safe and the interruption didn't cause anything serious.
@BabakR
If rebooting your phone does not work you may need to reconnect to the network. Turn airplane mode on for a minute. Turn airplane mode off. Check for a signal and /or your network settings  to make sure you are connected. Reboot again if necessary.
Edit: Reboot is to completely power off your phone then restart it vs just turning the screen off.
@BabakR wrote:
Thanks but not sure how to do that, it is a oneplus 7 pro
I think that gblackma means to turn your phone off for 30 seconds and to turn it back on, not to restart it multiple times.
BabakR
@BabakR restart your phone, wait 30 seconds and restart it.  Stay safe.
BabakR
"Sorry about that! Our team was recently made aware of an outage impacting multiple carriers in Eastern Canada. Services have been restored."
I am still unable to make calls, outside of Ottawa (West). I'm seeing the exact same error message that I've seen for the past several hours: "Mobile network not available"
And at the top it tells me that I'm only able to make emergency calls.
Please advise ASAP.
Thank you
Catherine_T
Retraité / Retired
Retraité / Retired
Hi there,
Thank you for your patience!
- The Public Mobile Team
gblackma
There seems to be an outage in Ontario outside of Toronto @Sheri1 . Check the map https://www.telus.com/en/on/outages  If you aren't located within the outage, try these  tricks to reset your service. You could try in order:
1.Restarting your phone. Turn it off, remove the SIM card, reinsert it, wait 5 minutes and restart it.
2.Putting your phone on aeroplane mode for 5 minutes. Take it off and restart.
3.From your self service account enable the lost/ stolen feature log out, wait 5  minutes, log in and take it off. Log out and restart your phone.
If they fail contact the moderators and ask them to reset your service for you.  There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
Triguy
gpixel
@Sheri1 depending on your location there is a service outage right now in Montreal and Ontario areas
https://downdetector.ca/status/telus/map/
