07-12-2020 07:30 PM - edited 01-05-2022 12:26 PM
Hi all, I've been with PM for almost 2 months now and it's been great except that I get a lot of people telling me they cant hear me and dropped calls when I'm in my basement. I never had this problem with Roger's which is who I had before. Is there anything I can do about it? Thanks
07-12-2020 11:26 PM - edited 07-12-2020 11:28 PM
@will13am wrote:@Gaf , take a look at the cell map and see which carrier has the best coverage for your location. Basements can be tricky. I don't get a strong signal with any of the major brands but enough to hold a call.
https://www.ertyu.org/steven_nikkel/cancellsites.html
Keeping that in mind, an LTE-only cell site will not help with voice coverage at Public Mobile. Also, even if this site lists band 2 and band 5, once again, that could be for LTE. Phone calls require HSPA network coverage to work.
07-12-2020 11:22 PM
07-12-2020 10:36 PM
3g seems to work better for me, no problem when I’m in the basement.
07-12-2020 09:50 PM - edited 07-12-2020 09:53 PM
Manually switching your network to 3g will not help with dropped calls or with people not being able to hear you. All phone calls are already on the 3g network.
It is possible that doing that will make it so that less calls will go directly to voicemail if the phone has difficulty switching over to the 3g network in time for an incoming call, but that isn't the issue that you had asked about.
07-12-2020 08:51 PM
07-12-2020 08:23 PM - edited 07-12-2020 08:24 PM
@Gaf You may have 3 bars but make sure calls work. Public Mobile uses 3G for calls and you said they had problems hearing you ? By switching to 3G you did nothing to solve the call issue. 3G is also slower for data speeds. Your basement doesn't get good cell coverage by Bell or Telus. I suggest buying a cell antenna booster.
07-12-2020 08:16 PM
Good to hear...and thanks for the advise in case that issue comes up again.
07-12-2020 08:13 PM
07-12-2020 07:58 PM - edited 07-12-2020 08:38 PM
07-12-2020 07:53 PM - edited 07-12-2020 07:55 PM
@Gaf Different carriers use different frequencies. Some phones don't support these frequencies. You have a Galaxy s8 so your phone dosent seem to be a problem. Galaxy s8's support a wide range of frequencies to work with all carriers in North America.
My guess is that your basement is a spotty zone.
07-12-2020 07:49 PM
I have the Samsung Galaxy a8. What do you mean band frequencies?
07-12-2020 07:48 PM - edited 07-12-2020 07:52 PM
@Gaf Its either your phone or the network. The Rogers network and Bell/Telus are way different. Rogers has different towers than Bell/Telus. Where I'm located Bell's network is far better than Rogers. If it ends up being the network then I suggest buying a cell signal booster.
Since Public Mobile uses Telus and Telus shares towers with Bell, Can you try using someone's phone with either a Bell or Telus carrier in the basement. Try to see if they get the problem.
It might also be the phone. Try to move your SIM to another phone and see if its just a phone problem.
07-12-2020 07:37 PM
@Gaf...try your sim in a different phone to see if that makes any difference.
07-12-2020 07:32 PM
Some areas.... Rogers works better while others. Telus.
which model phone do you have? Sometimes a newer phone have more of the band frequencies that offer better reception.
