08-17-2023 08:58 PM - last edited on 08-17-2023 10:25 PM by computergeek541
Someone made dubious transactions on one of my bank account and the security person at the bank suggested that I check if my phone had been accessed when I was sent an SMS with the verification code.
Please can anybody help me how to verify this.
thanks
Nicoleta
08-17-2023 10:14 PM
OK, Thanks I will move from them when this is finished.
08-17-2023 10:13 PM
Log in online. Then go to profile on your left side. There are 3 boxes on the right side. The middle says Your Phone number. There you will see your SIM. Just hover over the eye.
08-17-2023 10:11 PM
Please tell me how to find the SIM number in my profile. I could 't find it following the instructions:
1.Go to Profile and view your SIM number in the ‘Phone/SIM Info’ section
2.Confirm that the last four digits of the SIM in My Account match the one in your phone. If the digits do not match, you may have been targeted by a SIM swap fraud.
08-17-2023 10:08 PM
That explains it I was a victim of fraud myself with Tangerine the other day also other people I know had money randomly left their Tangerine account with fraudulent purchase they didn't make online
08-17-2023 10:02 PM
HI @DennyCrane
HSBC has it security app , technically even safer than 2FA sms, but it happens too
I don't believe the phone was the reason
08-17-2023 10:02 PM
it is Tangerine
08-17-2023 10:00 PM - edited 08-17-2023 10:02 PM
@hTideGnow My bank forces 2FA for adding a new interac e transfer contact. No sure if all banks are the same in that regard, but if this bank is it would make sense that they'd suggest this.
Most fraudulent online banking transactions are a result of a customer being negligent with their login credentials or they fall victim to a phishing attack. In either case it's the customers responsibility. It's not very often the banks online banking systems legitimately get hacked.
08-17-2023 09:57 PM
@DennyCrane wrote:So someone made a fraudulent transaction on your bank account and the bank is asking if someone had access to your phone to access the multifactor authentication code they texted to you.
HI @DennyCrane
bank like to take the responsibility off them, so the first thing they say, your phone got hacked. But adding a user on interac contacts, then process a debit, I don't think the leak on the phone
08-17-2023 09:55 PM
Not much PM can do if someone got access to your actual phone. Maybe change the device password. If you think someone cloned your sim card you can get a new one and change it yourself on your account.
08-17-2023 09:52 PM
@NicoletaD which bank was it?
I have a relative have the same thing with HSBC.
And, I don't think it is the phone is the source of the problem, cos HSBC needs a security app to add new names to the interac
08-17-2023 09:48 PM
Thank you.
Sorry, I'm a bit too emotional and angry, so I wasn't very coherent, I think.
Yes, I made a transaction at the bank and after that I closed and cleaned the browser.
A few hours later I received an e-mail from the bank saying that a person (whom I don't know) was added to my contact list) and that was it.
Naturally, I was surprised and went in to see what it was. The newly added person had made an interac transfer and had taken out some extra money.
Instead, the transfer I had requested was still pending.
Then I immediately called the bank's security and talked to them.
Now I hope it is clearer.
08-17-2023 09:39 PM
Thank you
I can tell you that I don't have many apps, the ones I have are from the google store, so I hope they are verified. Can you please suggest me some security software?
08-17-2023 09:30 PM
HI @NicoletaD
if you are concern it is the phone, you should wipe and re-setup your phone, no restore from cloud but setup new phone. And do not install any app from small name players, at least for now
08-17-2023 09:28 PM
yes I have
It was one of their ideea, the investigation didn't finish but I want to be sure that I can use mu mobile for other banks
08-17-2023 09:26 PM
HI @NicoletaD
I am not sure if PM agent can help with that, I don't sending them message helps
just check your phone, install some security software and scan.
uninstall all unnecessary app, those free app from unknown sources are dangerous
For any app you need to keep , check the security settings. Maybe ask someone with some knowledge to check for you as well
08-17-2023 09:25 PM
Usually your bank would never send you a code unless you have the 2FA for online banking
08-17-2023 09:21 PM
So it was the actual bank that sent you an SMS code? For what? Did you initiate something to get the code?
Or if it was a scam that pretended to be your bank, did you respond to it?
If so, you're on your own and customer service isn't able to assist you.
I think a lot of context wasn't given for us to make a proper suggestion to help you here today. And I don't think the solution you accepted will help you. But if I"m wrong, please come back and share how the solution worked. This is how we as members learn and help others.
08-17-2023 09:17 PM
I am not so familiar with the phone to do a screenshot of the SMS but was only a number sent by bank to log in
08-17-2023 09:15 PM
No it was a bank account that sent me a SMS code
08-17-2023 09:13 PM
thank you
08-17-2023 09:11 PM
We're going to need more information and maybe a screen shot of the SMS but please blank out your phone number.
It sounds like a possible scam. This will have nothing to do with public mobile. I think you may be on your own here. But once you give us more context, we'll help you figure it out.
08-17-2023 09:07 PM - edited 08-17-2023 09:07 PM
I would suggest you login to your account and change your password, check the registered phone number is yours and contact a CS_Agent to investigate at:
08-17-2023 09:02 PM
Was the transaction from public Mobile?
