12-31-2022 04:48 PM
Hi! Bought telcel SIM card (Mexico’s largest provider) for trip to Mexico. Limited wi-fi. Have you had good experience with it?
In their instructions it says iPhone may not be supported due to unlocking issue - contact your carrier (Public Mobile) to unlick it. Any problems with locking?
01-05-2023 12:14 PM
Simple...just answer the call as usually would.
01-05-2023 11:00 AM
One thing I don’t understand is telcel’s instruction to receive calls from Canada +52(10 digits) or 01152(10digits). Doesn’t one simply press the green button to answer the phone?
01-05-2023 10:55 AM
Ok thanks, making notes.
pS your Hairbag name is hilarious!
01-05-2023 10:49 AM
And another thing....when you dial someone back in Canada make sure to first dial 001...then area code...then number.
eg...001 250 608****
01-03-2023 11:48 PM
good question. Your contact list is still on the phone. No worrys. You won't have any trouble.
They do send a few messages in Spanish so learn how to use Gogle Translate.
01-03-2023 07:03 PM
@Traveler22 contacts for most people are saved on the phone and not sim. check it.
or you can check in contact on iCloud
https://support.apple.com/en-ca/guide/icloud/mmfba73ffb/icloud
01-03-2023 06:59 PM
Thanks! How do you text someone back in Canada. Is your Contacts list still on your phone with telcel SIM card?
01-03-2023 06:24 PM
as long as your iPhone is unlocked, the Telcel plan will be fine. I've been using the TelCel sim in my iPhone SE for about a week...works fine. Very impressed actualy.
I have the "Unlimited Friends Package" with 3GB of 4G data...about $15 / 30 days.
12-31-2022 05:16 PM
Hi! I checked the Settings - it is unlocked, thanks so much, I really appreciate it. I may test another SIM card as you suggested as well. Happy New Year! 🎆
12-31-2022 05:00 PM
@Traveler22 the disclaimer about locked phone should be just a reminder
You can check if your iPhone is unlocked here
Settings > General > About. If "No SIM restrictions" appears next to Carrier Lock, your iPhone is unlocked.
you can also try to get a sim card from another provider and test it on your phone. If it works, then your phone is unlocked
