I can't receive text messages
jrome032
New in Town / Nouveau en Ville
Since I switched to public mobile I have not been able to receive messages or calls. I can send messages and calls but I cannot receive. I need to receive text for bank confirmations. Please help.
2 REPLIES 2
@jrome032
Common mistake with new members is not replying to the text with the old SIM in your phone within the 90 minute window.
Just call the number @softech supplied.
@jrome032  Look like it is a stuck port.
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card and can only make outgoing calls,  then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get it fixed
