Here's what I think Public should do in regards with the Plans
makkahn28
They really should consider Only the 5G Plans, as the 4G LTE is practically default backup
They also should consider having 90-150 Day Cycle in their More Pricier Plans so that the savings would be worth that kinda investing
Starting off:
$15 500 Can-Wide Outgoing + Unlim Can-Wide Incoming + Unlim Global Txting + 500MB 5G Data
$20 1500Can-Wide Outgoing + Unlim Can-Wide Incoming + Unlim Global Txting + 3GB 5G Data
$25 Unlim Can-Wide + Unlim Global Txting + 8GB 5G Data
$30 Can-Wide + US L-D  Unlim Global Txting + 20GB 5G Data
$34 Can-Wide-US-Wide + Unlim + Unlim Global Txting + 40GB 5G Data
$35 Can-Wide-US-Wide-Mex-Wide(CA-US-MEX) + Unlim + Unlim Global Txting + 50GB 5G Data
$40 Can-Wide-US-Wide-Mex-Wide(CA-US-MEX) + Unlim + Unlim Global Txting + 80GB 5G Data
Then they Should at some point have Data Only for Tablets, Add-On Global Roaming to other Countries, perhaps in regions, like EU, Asia, and then fill in with Some Worthy Premium DIYS/ BYOD stuff as well
The 5G Unlim Data, perhaps that should be Discontinued, BUT having Longer Term Add-On Data, like instead of 30 Days, maybe lasting 180 Days at very Least
This way, that would be a Half-Way Point meet in Middle approach
If They Had Unlim Roaming Data, very least 3G Speeds
But, If one had Roaming Plans with Sizable Data Allocation, Unlim Roaming Data would be Moot
They Should also have Family Share plans too, Public could Benefit from such a Greater means
Yes I know it’s why I asked if you meant unlimited data on the roaming plans too , as it wasn’t clear in your suggestion, but I like your thinking and wish it was unlimited data on the roaming plans like Telus has
adding @makkahn28  and to offer 5G+ speeds too would be amazing
The Plans with the US-Wide and Now Mex-Wide Do Not Have Unlimited Data, Only the Can-Wide Only
@makkahn28  They already have and had the $34 plan you suggested and currently still have the $35 plan your suggested
unlimited talk and unlimited international text , or did you mean unlimited data too on the roaming plans ? Because the 5G non roaming plans have unlimited data already
makkahn28
Then, Add the Watch and Wi-Fi Call as well
That would at least give Public the Communications Muscle to say that The Public Deserves Better and We are the Public
