5G data cellular data anyone?
will13am
8 REPLIES 8
will13am
I picked up 5G again.  Burnside area in Victoria BC.
I should clarify that mobile data is working.  No I will not attempt a speed test.  I probably don't have enough data to complete a single test.
I think it's most likely a bug in the phone software, less likely a bug in the network software.
5G has been around a while but it's still not mature and widespread enough to be fully debugged, fully predictable, fully compliant, fully standardized.
LeePublic
Hmm..... Could it be a accidental testing for the near future 🤔
ShawnC13
@will13am  this is interesting as you don't have a Telus supplied phone do you?  Everyone mentioning how it would have to be a telus provided phone to get 5G even on higher tiers
@hTideGnow wrote:
did you try to use some data and see if the 5G stays?  and speed test?
Are you kidding?  You want me to do a speed test on 5G?  I don't have an unlimited data plan.  The 5G connection did not last too long.  I was on a moving bus.  I didn't think of getting off and taking the next bus.  🤣
@hTideGnow wrote:
HI @will13am
which province you are at?
my voice and data still shows LTE...  😞
 since you might have 5G.. you have VoLTE as well?
Toronto.  My voice connection shows as LTE when idle but it never holds when a call is initiated.  We had another member thinking that they had a VoLTE call and it was confirmed to be untrue.
HI @will13am
