Reply
Re: wrong info when I call on others phone
@simranwings
Easiest way is to change phone numbers.  If not possible, you might be out of luck.
I guess that you could try to contact moderator/PM employee to see whether they can do anything about it.  Click on quesiton mark on right lower corner of website to start ticketing process.  Not sure whether moderators can help this situation.
@Dunkman wrote:
@simranwings
As you've already discovered for @simranwings , all 365-998 numbers are bramptom numbers.  Moderators can't change the city that a phone number is assigned to.
@simranwings wrote:
it is a new number. I selected here on public mobile. so I cant change the number as it is important for my job. please advice
Sorry, but you don't have much of a choice. I've looked at 905, 289, and 365 area codes, and the only one of those area codes with OCN of 8303 next to it for 998 is the 365 area code. 365-998-xxxx are all Bramptom phone numbers. If you don't want a Bramptom number, you will need to change it. An alternative would be to get a Woodbridge number as you desire and the  forward calls to your Bramptom number.
@simranwingsThe provider which allows one to put their name on the phone number is Rogers (the top tier level). If being able to control your name on your listing is important to you, I suggest you move to Rogers.
As a few people mentioned (correctly) above ALL numbers under that series are Brampton numbers
Hence long distance claims (Vaughan to Brampton despite how close they are IS a long distance call)
Your only choice is to change your number
