Reply
Highlighted
setting up voice mail message
hello all, i would like to know how do we set up a voice mail?
It does give me an option to record the voice mail, but i do not want a recorded voicemail.
I want it to say "you have reached the voice mail number (647-999-9999)" as an example. How do i make it say my voice mail number instead of my recorded voice.
Please and thank you!!
Accepted Solutions
Highlighted
Retraité / Retired
Re: setting up voice mail message
Hello @Saddal82 🙂
If I understand correctly, you are trying to set a standard greeting message?
  • From the handset, dial 1+ the 10-digit phone number + Send.
    or
  • From a landline, dial the 10-digit phone number and press the star key to interrupt the system greeting
Enter password when prompted
Press 3 for Greetings options
Press 1 for Personal Greetings options
Press 6 to activate standard systems greeting
Please let me know, if this helps you.
Thanks 🙂
Shazia
All Replies
Highlighted
@Saddal82 Good question! Our community moderator @Kalla_A may be able to answer this question for you.
Highlighted
Retraité / Retired
Hello @Saddal82 🙂
    or
Thanks 🙂
Shazia
Highlighted
hello, i did follow the steps and my standard messaging is activated but it says your recorded name is "..." and it doesnt say anything neither my name nor the mailbox number.
Dialing it from the landline, can you be more specific how to set the voicemail from landline, maybe that will work next time?
but other than that is there any other option where my mailbox number is prerecorded?
please and thank you!
Highlighted
Legend
Hello @Saddal82,
There are 4 types of greetings: personal, busy, holiday, and extended absence. You want the personal greetings. They will provide you with 3 options:
1: your number and unavailability are stated, but your name is not mentioned. This is the system greeting by default.
2: your name, in your own voice, and unavailability are stated, but your number is not mentioned. This is a semi-personalized greeting.
3: you record your own announcement, as you wish it to be. Your greeting can be up to 60 seconds in duration, and messages up to 5 minutes in length. The system will not add your name or number to your greeting.
If you want your phone number to be included by the system, the only greeting that has that is #1 above. If that is unacceptable to you, #3 above is an alternative, but the entire greeting will be in your voice as nothing is provided by the system.
Creating a message from a landline provides no additional options as if the call were made from your Public Mobile number.
I hope that this has addressed your concerns.
Highlighted
I was trying to do the same...have a generic greeting play, but not my name or number in my voice.
During setup, i was forced to record a name.  Afterwards, I was able to go back in personal preferences and delete my recorded name.
Now, I have system greeting with my number NOT in my voice (generic as it can get).
Highlighted
These instructions are not correct because when I called my number from a landline and press * the automated system tells me "you need to call from your own phone to setup your voicemail, goodbye".
Highlighted
The comments I made yesterday are actually partially true.  Here is what I said yesterday:
"These instructions are not correct because when I called my number from a landline and press * the automated system tells me "you need to call from your own phone to setup your voicemail, goodbye".
This "you need to call from your own phone....." error message only occurs if you have NEVER setup your voicemail which was the case for me.  I just signed up yesterday with Public Mobile and I wanted to setup my voicemail for the first time using a landline which is not possible however once you set your voicemail for the first time with your cel phone then it is possible to get into your voicemail options using a landline by dialing your phone number and once your voicemail message starts by pressing the * button on your landline phone.
Hope this clarifies things.
Highlighted
Setting up 100% system voice greeting
After press 1, I pressed 6 trying to activate standard systems greeting. but it says invalid button.
I want to use 100% system greeting instead my voice.  I tried all my efforts to follow the instruction, but with no success. I have no way to delete my recorded voice.
Highlighted
Re: Setting up 100% system voice greeting
I suggest you email a Public Mobile moderator for this by reading below on how to contact them:
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
