registering for self serve
jnwilliam
How do I register without a public mobile number. I am trying to activate my sim, but I would like a 514 (Montreal) area code
DarianDNewell
Do you have any more questions?
will13am
@jnwilliam , if you are activating online yourself and not at a store, the steps are generally as laid out in this illustrated guide.  Phone number selection is covered.
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Start-Guide-Setup-Activation-Port-Dat...
HALIMACS
Hi @jnwilliam
Do you mean you're porting a number from another provider and you don't want Public Mobile to choose a number for you?   Or, that you're not in the Montreal area but would like a Montreal based area code?
Your options for phone numbers will depend on the location registered on the activation process.
After the number is assigned, you're permitted once change per 30 days, free of charge.
I'd recommend reading this document and below is where on self-serve you can change your number:
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
jnwilliam
thanks
Dunkman
@jnwilliam
You will need to activate a PM Sim card/account to make a self service account.  If you activate at home, you will automatically make a self service account with email address as login and you would choose your own password on activation.  If you activate in store, you will need to return home and activate a self service account at home.
