recently ported from bell , cant make any call, plz help
liny
hi
I recentlly ported from bell , i received a message port done successfully. I cant make any calls or text , it says you dont have a call plan  and says add plan . But i already paid 35$ unlimited calling pan
I cannot see any detalis in my plan details when i login to my account , it says
(As of today your estimated payment is: $0,,Your next plan cycle starts: Dec 31, 1969)
12 REPLIES 12
liny
thanks
@liny wrote:
I choose 35$ plan when I activated my sim , and my credit card got charged.
@liny  From the screenshots it appears that the plan is not selected.It shows that you have $35 in your account so just go into plan and add-ons and select your plan and everything should start working.
JaimeLaPizza
From what I see, you have 35$ in your account, but it has not been applied to any plan...
liny
liny
Hi this is what i can seeHi this is what i can see
Thanks
geopublic
@liny wrote:
hi
@liny  From what you describe it doesn't sound that your plain has been selected. When you say you paid do you mean that you have added the $35 to your account funds? When you login into your account you should be able to see your plan details. Can you post a screenshot of your payment history minus your personal info of course?
liny
Thank you,,
JaimeLaPizza
@liny look back in my previous posts, click on the links.  You may also try @cavemantoronto's ideas, sometimes the moderators may take some time to answer....
liny
thanks for your replay, how do I contact moderator
JaimeLaPizza
@liny you are new to Public Mobile so you are probably not familiar with the moderators, so here is more info.  Hope everything is solved soon.  Here are the moderators' hours of operation.
cavemantoronto
@liny wrote:
hi
Try go into self-serve and reporting your phone as lost.  Then, report it as found.  Also, try paying $1 to account.  If that doesn't work, contact Moderator_Team as said earlier.
JaimeLaPizza
Hum, usually when you get the text message saying everythig is OK it really is.  Your self-serve account is acting weird.  Time to contact a moderator in my opinion, use this link.
