11-18-2019 11:17 AM - edited 01-05-2022 08:01 AM
11-19-2019 03:46 PM
I have had the same problem. I tried Midori in private browser mode and got:
"Midori can't find the page you're looking for
The page located at “selfserve.publicmobile.ca” cannot be found. Check the web address for misspelled words and try again.
Unacceptable TLS certificate"
I am getting less and less impressed - cheap is not everything.
11-18-2019 11:22 AM
Try using a different browser and incognito mode. Also clear your cache and cookies then reboot. If you still have problems then submit a ticket by clicking on the question mark on the bottom right.
11-18-2019 11:19 AM - edited 11-18-2019 11:24 AM
Are you sure it is the right email
Did you signup on store or online? Did you create the self-serve account already?
Can you locate the welcome message (not from community but for the self-serve)
If it's all yes you will need help if moderators
