porting of old phone number
rgess88
my old phone number has not properly ported to puplic mobile . missing old pin number to port
9 REPLIES 9
@rgess88  Speakout does not use account numbers so that is why you need to provide you PIN or IMEI to complete the port.
To submit a ticket to Public Mobile do the following: PMST.png
popping
@rgess88 wrote:
yes from speak out
Read my post on how I port my Speakout number to PM in 4 hours without moderator help.
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Porting-number-from-Speakout-Apply-al...
Your port is stuck now.  Read my phone and provide moderator that used to moderator.
Create a moderator support ticket using the ? button at the right side bottom corner of this page.
Type "contact human" one or more times. SIMon will eventually show you the "Submit a ticket" button. Click on submit button to get the create ticket screen.
Moderator wait time is up to 2 days.
rgess88
I did give the account nuber, but speal out also has a pin nuber that I did not provide
rgess88
yes from speak out
PAULRANG18
You only need your present account number to port to PM or any other carrier. Never heard of a PIN being needed before.
geopublic
@rgess88  Are you porting from Speakout? That is the only provider that requires a PIN to port for all other providers best to use account number.
dabr
Where are you porting from?  Porting can also take 2 to 4 hours to complete.
You shouldn't need a PIN to port, but you would need your old account number and keep that account active until the porting is completed.
ooakosiryan
Sorry to hear you are having issues porting.
You'll need to submit a ticket for Moderator assistance. You can click on the question mark in the bottom right and enter some words about your issue until it lets you create a ticket.
I'm not sure what you're referring to when you say missing old pin. Porting doesn't require a pin. You just need the account number.
Good luck!
Lar
@rgess88  Are you saying you didn't  give PM the old account number and information needed to port over your number?  Could you explain in more detail, thanks
