phone number change
creatorsgift_1
how can I change my number or area code
9 REPLIES 9
@creatorsgift_1 ,  I have moved your question to it's own thread so that it will be easier for you and others who may have the same question to more easily find the answer.
If you haven't already tried, please use the instructions provided earlier for changing your phone number.
SD08
@Dankaroo  wrote:
I do not know if issue is resolved (41 pages...) If it is please mark a solution. For any reward inquiries please refer to the following link
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/General-Reward-Rules/ta-p/164
@Dankaroo  The original post of this topic was an informational article about "Community rewards."  As such, it does not require a solution.  Original posts which do not request help from moderators or community members should not have a solution marked.
EDIT:  The off-topic tangent into which the surrounding posts diverged have now been separated into their own topic (phone number change), so now a solution could be appropriately marked.
Dankaroo
@CS_Agent wrote:
 Hey @creatorsgift_1!
Thanks for being part of our community.
The quickest way to change your phone number will be by logging in to your self serve account, select the tab "plans and add-ons", and you will see a sub-tab that says "change my number"
If you have any further question, you can send us a private message and we will be happy to assist you.
Kind regards,
Monica
Public Mobile Community Moderator
CS_Agent
Customer Support Agent
Kind regards,
Monica
Felixbthe1
You can change your number in the self serve option of your account when you sign in.
I need help toto change my number
creatorsgift_1
Thanks
It would be easier and faster to have help if you post your question in a new thread @creatorsgift_1 ..here...
https://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/getting_started
Ok @creatorsgift_1
you can change your number in your self serve account in PLAN AND ADD-ONS you will see change your number...
creatorsgift_1
