01-22-2020 10:13 PM - edited 01-05-2022 09:08 AM
I no longer remember both password and security questions. What steps do I need to take to reset everything in order to have access to my account?
01-25-2020 07:55 PM
01-25-2020 07:51 PM
@CannonFodder Thanks for replying to my concern, but I have since received a msg from a moderator and is in the works of getting it resolved. Thank you!
01-23-2020 07:37 AM
@nadia100 wrote:Good morning i need help to activate my sim card i am having problems putting my informatin.
Help please.
@nadia100 Do you still need help? If you get an error you will have to wait one hour before trying again. Make sure you clear your browser and use secret/incognito mode in chrome or Firefox as they work best on public mobiles site. Don't forget to enter your referral code halfway down the first page. When you get to the payment section copy your address exactly like your billing address except leave the apt/unit box blank and do not put a space in the postal code. USE ALL CAPS if necessary. Good luck....come back if you still need help.
01-23-2020 02:02 AM - edited 01-23-2020 02:12 AM
Whaddaya mean "good morning", it's only 11pm, out here on the wet coast! 😉
It would help if you'd provide a little more info. What sort of problems are you having?
Oh, and btw, you should have started a thread of your own, rather than piggybacking on this one.
01-23-2020 12:56 AM
Help please.
01-22-2020 10:29 PM
I was informed that it may take a while going through a mod but it appears I have no other options since ticketing method did not work for me.
I appreciate your suggestion nonthless.
01-22-2020 10:25 PM
@TrishD1 wrote:I appreciate your feedback. I have tried contacting a moderator which I'm waiting for a reply. As for creating a ticket, I tried that however it asks for me to verify pin which I have tried to retrieve through my email but no email has been sent.
I'm hoping by dealing with the moderator directly I won't need to go through this ticketing prcess.
If you encounter problems with submitting a ticket, you can click here to send a private message to Moderators, but this alternate contact method may have longer response time.
01-22-2020 10:21 PM
01-22-2020 10:14 PM
You will then need to contact moderator to access your self service account.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
