Reply
seallaibh
newbie needs help
Hello All.
New to this community.  Just activated a new account on the 23rd of July.  I can phone or text text, but can't send pictures by text. Voice mail and caller id work perfectly.  My big problem is that I'm not able to access my mobile data.  I'm in Newfoundland, if that's relevant.  The phone is a new phone just released in April.  It's not no anyone's lists of phones (compatible or otherwise) but the information about the bands it can operate on seems to be compatible with those PM uses.  Any suggestions?
mimmo
Re: newbie needs help
@seallaibh  you need to set up your apn settings.
see details on this link https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-...
 edit fixed link
ShawnC13
@seallaibh wrote:
Hello All.
You will need to setup your APN here is the best site I have found for doing that https://apn-canada.gishan.net/en
I am happy to help, but I am not a MOD please do not include any personal info in a message to me. Click the  in the bottom right to create a trouble ticket *
mynamejc
dna2016
@seallaibh ya sounds like an APN issue. As the others have mentioned you'll need to check your settings to see if there needs to be some updates.
@mimmo you'll need to use a new link, when I click on the link you provided it doesn't take me to any type of APN settings.
mimmo
@dna2016  thanks fixed link.
RobertQc
@seallaibh
You may need to configure your APN settings to be able to send pictures (MMS) and navigate on internet (DATA).
Your "Mobile Data" also need to be activated. Android APN step-by-step configuration :
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Click here for Android APN Screen Shot
You will need to input the following information :
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,dun
Select Save/Done. Select Public Mobile to connect to the Public Mobile network. If its not working try below.
Here is the highest detail.
APN Settings:
 APN: sp.mb.com
 Proxy: Not set
 Port: Not set
 Username: Not set
 Password: Not set
 Server: Not set
 MMS proxy: 74.49.0.18
 MMS port: 80
 MCC: 302
 MNC: 220
 Authentication type: Not set
 APN protocol: IPv4
 APN roaming protocol: IPv4
 Bearer: Unspecified
 MVNO type: GID
 MVNO value: 4D4F
ALSO, Here's the Tethering APN Settings As Well:
APN Tethering Settings:
Name: Tethered Mobile Internet
 APN: isp.mb.com
 Proxy: Not set
 Port: Not set
 Username: Not set
 Password: Not set
 Server: Not set
 MMSC: Not set
 MMS proxy: Not set
 MMS port: Not set
 MCC: 302
 MNC: 220
 APN type: dun
 APN protocol: IPv4
 Bearer: Unspecified
 MVNO type: GID
 MVNO value: 4D4F
dna2016
@RobertQc ya better to do copy paste as opposed to using a link.  Links can break.
seallaibh
Thanks RobertQc and everyone else who replied to my Mayday call.
My phone doesn't want me to edit my APNs -- I have an edit screen, but everything is greyed out and I can't change anything.  Does anyone know a work around?
My APN is set to sp.koodo.com and the mms is set to http://aliasdirect.net/proxy/koodo/mmsc.  Everything else is the same.
RobertQc
@Didn't see this till now, without adding someone the AT " @ "symbol @RobertQcwith a name like @seallaibh and a name, I don't get notified there is a new post sorry.
Try refreshing your network operator list and manually connecting to public mobile, then rebooting your phone, then try to change the settings again.
