need to change email associated with my account
ramani
Hello,
I need to reset the password for my account. I forget the current password and when I try to reset the password I get the following error in a grey box.
"ForgotPassword/LoginUnsuccessfulUser_LoginDisabled"
I am not how to go about reseting my password.
thanks
@ramani wrote:
Hello,
thanks
You have two parts here.
Reset password: as kselmak wrote above with incognito and cache and browser. sometimes the reset never sends an email. Or it might land in your junk folder.
Change email on account: this needs the moderator regardless of you logging in to your account after resetting the password.
Failing the reset then you'll still need the moderator.
@ramani
If the password reset function is not working, you will need to contact modertor.
Send a private message to moderator through the following link :
hairbag1
You'll need to contact a moderator for their help.....Click this to message moderator
Please be patient as it could take 48 hours to get a response...usually much less.
Good luck.
kselmak
Can you try in the incognito mode of your browser? Do you get the same thing?
