my account
alcraft2015
why cant I log in ?
11 REPLIES 11
sunnyday1427
Whats the error message you are getting please?
Staliger
@alcraft2015 Did you have a chance to deal with the issue? Please let us know so we could advice further if needed. Thanks and stay safe.
popping
@alcraft2015 wrote:
why cant I log in ?
If you activate you PM plan online, your PM self-serve account was created for your during the activation process.  Your PM self-serve username is your email address and use the password you supplied during activation.
If you activated your PM plan in store, you need to create your self-serve account at home using the Create Account button on the login page.  https://selfserve.publicmobile.ca/
You need to turn on your phone to receive a code to create your account.
@tamianddan wrote:
Try to reset your password, also double check that you have the correct username or email. the username is just your email without the end part. Hope this helped 🙂
No, username is your email address including the @gmail.com or @outlook.com. It will not work without entering the full email address.
Please note this isn't correct and to double check your informaiton before posting. Any part of the e-mail address omitted will prevent someone from logging in.
@tamianddan interesting, I'm gonna try this.
*fail
tamianddan
Triguy
Try using a different browser and incognito mode.  Also clear your cache and cookies then reboot.
Staliger
@alcraft2015 If reset password didn't help, then you have 2 options:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
gpixel
@alcraft2015 hi, try using your browser in incognito or private mode before you try the password reset option
Dunkman
@alcraft2015
Did you forget your password?
You could try to reset your password.
https://selfserve.publicmobile.ca/forgot-password/
IF that fails, you will need to contact moderator to get access.
To contact moderator via 2 methods:
  1. Ticketing system - faster response time
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator.  Type: Contact moderator. Follow the prompts to submit ticket.
or
2 Send a private message to moderator through the following link :
