Reply
iPhone XS can't send MMS pictures anymore to Android devices
This is weird but I changed plans on January 21st  from less gigs to more gigs and now having difficulty with sending pictures in iMessage unless the enduser has an iPhone and I send to the Apple Id account.
Safari works great, wifi works great, phone works and everything else works.... just not sending pictures via iMessage to android devices
My plan says:
  • This plan includes: -
  • - 5GB at 3G Speed
  • - Unlimited Canada-wide Talk
  • - Unlimited International Text
My plan does not say,
Unlimited local text or picture texts
Can anyone weigh in on this or know why I can't send mms pictures to an android device?
thanks
Re: iPhone XS can't send MMS pictures anymore to Android devices
My plan says:
  • - 5GB at 3G Speed
thanks
Hi,
Can you confirm that MMS messaging is still on under settings-messages?
Also when you say safari works great, etc do you mean while on data?
EDIT: Do you know if this issue as been since you changed your account?
Did you try with your wifi on off @Nickintofino??
@Nickintofino Also try cycling Airplane mode on then off.
I checked this out right away, turned on and off to see if that would make a difference too
On data or wifi, tcp/ip is working, I just thought someone would ask this question, it really has no baring on mms
Yes since changing my plan, previously it worked fine. I have cycled the iphone on/off a few times too
yes, many times
cycling airplance has been done since I changed plans and there hasn't been a difference
Notice the plan doesn't say local texting or mms with pictures?
I checked this out right away, turned on and off to see if that would make a difference too, This will do exactly what you mentioned but should be giving you a warning when you try to MMS an Android.
On data or wifi, tcp/ip is working, I just thought someone would ask this question, it really has no baring on mms The reason I asked this is to determine if your Data was working. No a MMS don't use data but it does use the service to send the MMS, thus it needs to be working.
This is included with the plan!
