Reply
Highlighted
iPhone 11 max and account activation
It says I cant receive  text or call on my iphone 11 says to choose another plan
Secondly  I cant activate my self serve acct. I cant login and  I cant reset password  keep saying cant verify my email  I tried to create a new account  and it says my number  is invalid.  Am just frustrated.  .I bought my phone at fiull price dont expect it to be locked
Highlighted
Re: iPhone 11 max and account activation
Can you call out and send texts?  Did you port a number in?  For the password, you'll need to click on https://publicmobile.ca.ada.support/chat and type "forgot security".  If data, outgoing calls, or outgoing texts work, your phone is unlocked or a Telus phone.
Highlighted
I can’t call or text out it says it’s not included in my plan I did the 15 dollar plan . When I tried to text I get a message saying not included to go to self serve and update But I can’t acces my account
Highlighted
You'll have to reach a moderator. They're the only people.to fix an account issue. The provisioning got messed up.
Highlighted
So frustrating!
Highlighted
@faithsayo1
you can also send them a private message through here
make sure to check your inbox(top right corner envelope icon) periodically, for a response
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM EST
Highlighted
Hi @faithsayo1 ,
Just making sure...you are using a Public Mobile SIM card, correct?
Highlighted
Of course. Infact I have 2 public Mobile sim and I can’t login to both accounts while the ported in number works fine . The new number sim says calls and text are not included that I should login to self  serve to update my plan but I can’t login in
Highlighted
Thanks
Highlighted
HI @faithsayo1 , ok.
Did you only port in one phone number? If so, I am wondering why you are referring to two accounts?
