Reply
Highlighted
forgot password and account locked
I decide to buy an 30$ plan with autopay than I try to get in my account and its show that the password is incorrect than I try to do the password reset and its show: your account is locked please contact public mobile. Please help me
Thanks
edited by computergeek541: phone number removed
Accepted Solutions
Highlighted
Re: forgot password and account locked
@Ravi1971 try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue password reset, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
All Replies
Highlighted
Highlighted
Hi @Ravi1971
This is a public forum, please edit your post to remove any personal information. To edit it, hit the 3 dots at top, right of your post.
To contact the Moderator_Team, there are two ways to reach them:
1-Click the question mark on the bottom right hand side of your screen to talk to SIMon the chat bot.
https://publicmobile.ca.ada.support/chat/
OR
2-Contact the Moderator_Team via private message using this link.
Highlighted
xxxxxxxxxxx
xxxxxxxxxx
Thanks
@Ravi1971 contact a moderator  click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator say you want a password reset      check the envelope top right corner for a reply response time is 2 to 48 hours
Highlighted
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Highlighted
Ravinthiran
xxx-xxxx  <-------
Thanks
@computergeek541
Highlighted
Re Entering wrong password for account, perhaps Public Mobile should not limit the amount of attempts to 2 tries.  Perhaps as many as 5?
Tags (2)
Highlighted
The limit is more than 2 attempts. I do believe that the limit gets lowered if the you're never logged in successfully after a previous time-based lockout.
