04-29-2020 10:27 AM - edited 01-05-2022 10:34 AM
I need to get into my account but I forgot my sign in information but I have my phone number from public mobile. I need to get into my account to change my credit card information.
Please help me.
05-02-2020 02:03 AM
@JoyLuck wrote:
Please do what @hairbag1 suggests about deleting your personal info in this public forum.
Edit: @computergeek541 Could you please edit out 2 posts of personal info. TIA.
Hi @JoyLuck. I've stepped away from Oracle responsibilities. So, I'll tag @Luddite for you to get this done. Thanks.
05-02-2020 12:34 AM - edited 05-02-2020 02:01 AM
05-02-2020 12:30 AM - edited 05-02-2020 12:44 AM
@Jaqith wrote:
xxxxxxxxxxx
Ok. So there's your email address which is your username. Click on Forgot your password? and enter that username and continue with the other instructions. Can you remember the question and answer you chose for the security question?
What is it you're trying to do by the way?
Edit: @Jaqith : so I took the liberty of trying that email address and indeed it doesn't work. Do you have any other email addresses? Don't post it here...just try it in the Forgot your password? feature.
05-02-2020 12:25 AM - edited 05-02-2020 12:26 AM
@Jaqith wrote:*** *** ****
As this is a public forum...everyone with a computer anywhere in the world can see your phone number and your email address. Click the 3 little dots in upper right side of your original post and edit out such sensitive info.
05-02-2020 12:24 AM - last edited on 05-02-2020 02:12 AM by NDesai
xxxxx@hotmail.com
780-xxx-xxxx
Personal info removed by NDesai
05-02-2020 12:24 AM
@Jaqith wrote:xxxxx
Look through all your email inboxes for the welcome email from here. That gives you your username. Then try the Forgot your password? link.
05-02-2020 12:21 AM
05-02-2020 12:21 AM - last edited on 05-02-2020 02:12 AM by NDesai
780-xxx-xxxx
Ph number removed by NDesai
04-29-2020 12:03 PM
@mathewpaul If you still couldn't get access to your account, there are 2 options: contact moderators through clicking on ? on bottom right of the page and following directions OR directly through the private message here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Ask them for a temporary password.
04-29-2020 11:19 AM
Maybe, because we are human?
Regards.
04-29-2020 11:17 AM
how do so many people forget the email they've signed up with?
04-29-2020 10:38 AM
@mathewpaul , check your emails to see which account was used to activate the online account. You should have received a welcome email when you activated. That should be the queue which email was used. Use the email in the forgot password feature to do a reset.
04-29-2020 10:31 AM
You'll likely have to contact a moderator...click on the ? in lower right side of screen to start the process.
or contact them with a message:
Regards.
04-29-2020 10:29 AM
@mathewpaul Hello to sign into your self serve account all you need is the email that you signed up with you should be able to reset your password good luck
